Hyrdostat 3250 Plus Temp Display Flickering
SunRad
SunRad Member Posts: 8
I just installed the Hyrdostat 3250 Plus to replace an old Aquastat on my Burnham 240k BTU hydronic boiler. I opted for wall mount since the space is tight on the side of the boiler and I wanted the ability to adjust the settings easily if needed.
I confirmed the unit is grounded by testing between L1 and GRD and it shows 120V on my multimeter. It's also using the Thermowell for LWCO functionality which is working correctly. The only issue is a slight flicker on the temp display. I'm wondering if this is normal or should I replace the unit? The flickering you see in the video is exactly how it appears in real life.
https://youtube.com/shorts/cvZWmwVcfZw?si=s22f4CS8MDC7giCa
Thanks for your help!
    EdTheHeaterMan Member Posts: 12,127
    edited November 2024
    Pacient: “Doctor, my shoulder hurts whenever I hold my hand up like this”
    Dr. : “Don't hold your hand up like that”
    Stop looking at the display. it is just fine.
    SunRadMikeAmann
  • SunRad
    Thank you @EdTheHeaterMan. Will do.
    109A_5 Member Posts: 3,956
    Probably just a poor job of multiplexing the display. Probably normal for that unit.
    SunRad
    HVACNUT Member Posts: 7,424
    They don't call it a "Dynamic Display" for nothing. If you put on the Wizard of Oz, and start the Hydrostat at the 3rd roar from the MGM Lion, you'll be in for a real treat.
    SunRad
