Hydrotherm HI-125b Manual
HeatingHelp
HeatingHelp Administrator Posts: 722
This discussion was created from comments split from: Hydro Therm HI-125B with a LOW and/or Automatic firing?.
  • Maynardb
    Maynardb Member Posts: 1
    edited October 2024
    I saw this post from a few years ago and am hoping that someone knows where I can get a manual for this same boiler. I have a Hydrotherm HI-125b as well Mine seems to cycle too much and I want to check the correct settings for the aquastats. There’s one in front and the a smaller one in the back by the circulator pump
    Thx
    Bruce
  • HeatingHelp.com
    HeatingHelp.com Member, Moderator, Administrator Posts: 227
    Welcome to Heating Help @Maynardb! I've created a new discussion for you here so that your post doesn't get lost at the bottom of an old discussion.
    Forum Moderator
    EBEBRATT-Ed Member Posts: 20,145
    @Maynardb
    Aquastat settings for boilers are pretty much the same regardless of make.
    Do you get domestic HW from the boiler?
    Can you post pictures of the boiler and the aquastat model #s?
    Typically I would set the high limit at 190. If you have a low limit or low limit circulator relay they can be a little fussy depending on the DHW capacity of the coil. Pictures will help.
