Tub shower valve ID
One of our new customers just moved into town, the house was flipped by a flipper. Unfortunately, a knucklehead got involved and put Delta trim on top of this unknown valve body. Does anybody recognize what brand this is so I can get him the correct trim? The current set up is useless, handle just spins. It’s probably a big box special.
Looking like Glacier Bay. Thanks for peeking
Yes, frankly- I never touch those, I always go to the main house shut off. With my luck, they would start dripping!
3 -
they make goof plates where you can change it from the front
Yes, it doesn't offend me that badly. If the valve works, it can stay. Hacking that tile apart looks brutal.
Looks like you're going to need half a tile for the trim to cover the hole
For showers I built, I use Kohler valve with replaceable cartridge but what happens when the cartridge is no longer available? Time for new shower if valve is in an inaccessible wall.
I notice a lot of European bathroom utilize a configuration that looks like US commercial valves with hot/cold 1/2” mpt at 8” spacing that allows for replacement of complete valve and spray assemblies without any change to internal wall plumbing. I can definitely see the advantage.1
- 120 Geothermal
