Gas Valve
BellaireBoy
Member Posts: 2
in Gas Heating
Does anyone know where i can get the allen head screw that goes in the gas valve test ports…comes out with a 3/32" allen wrench….need a couple replacements….gas valve is a White Rodgers 36J24-205… Thanks in advance…
Nah, these are li'l Allen setscrews ground to a point. The secret is that you don't remove them, just crack them a turn or so. That'll be plenty to check pressures (but not purge air, not that I would ever do that…)
I'm afraid that the only replacement source that I know of is a donor valve. I used to keep a few of those, and the ⅛" plugs, on hand from when I condemned a valve.1 -
i agree on the donor valve…but need someone who has one…and yes they are tapered at the bottom so they can seal.
thx.
- 167 Indoor-Air Quality
