Name this fitting
I've got an AGA gas cooktop that has a slight gas leak. Using a flammable gas detector, I isolated the source to one fitting.
The fitting looks like some type of flared fitting. It had a stiff washer in it too. Before I try tightening it up again, I would like to know more about it. This is a British-made cooktop.
I am not sure exactly how the washer that was in it is supposed to function. It does not seem supple enough to form a seal, so maybe it sits on the back of the upper nut (not shown) to prevent galling as the nut is tightened?
Here's a pic…
BTW, here's the washer. It's not 100% obvious to me what role it has.
Thanks! That helps me a lot!
I notice there's some discoloration on the part that seals. I wonder if that's some kind of contamination. These types of couplings are supposed to be strictly metal-on-metal, right?
I am tempted to try cleaning it off. Perhaps removing the corrosion on the outside upper pipe with steel wool, and using isopropyl on the mating surface.
Name this fitting
OK I will play. Since it is on a British made cook top… I will call that fitting Kipper! From the cartoon
I just looks like a Kipper to me. Let ms know what other names you get!
Looks like half of a union and a flare adapter for a flexible gas connector
- 120 Geothermal
