Backflow vent leaking.
Weil McLain Gold
9D-M3 Back flow
Watts pressure regulator 12-15
Turned on heat for the year, lots of air in second story baseboard so I went down to look at the boiler pressure was low almost on zero so I manually added water pressure regulator. 9D-M3 started leaking from the vent afterwards, seeing it was old anyways I just replaced it. Before installing new I did flush out the inlet supply line as to not run any sediment through new back flow. Now back flow still leaks but I believe it is only leaking when the boiler cycles? Pressure on gauge is 14ish at 200° obviously drops as temperature cools off have also have to add water as the air has been working its way out. Any ideas? Thanks!
Edit one thing to add, I know water pressure to the house is above 12-15 psi as I have a pump that pulls it up from the city gauge reads 55psi on that tank.
Brass plug
Thanks! Is it normal to only be dripping when the boiler is firing though? Dry when boiler not firing.
Can brass plug cause any problems?
I am not sure if a vented BFP is code for the job …..
