Backflow vent leaking.
mike3181
mike3181 Member Posts: 15
edited October 2024 in Oil Heating
Weil McLain Gold
9D-M3 Back flow
Watts pressure regulator 12-15
Turned on heat for the year, lots of air in second story baseboard so I went down to look at the boiler pressure was low almost on zero so I manually added water pressure regulator. 9D-M3 started leaking from the vent afterwards, seeing it was old anyways I just replaced it. Before installing new I did flush out the inlet supply line as to not run any sediment through new back flow. Now back flow still leaks but I believe it is only leaking when the boiler cycles? Pressure on gauge is 14ish at 200° obviously drops as temperature cools off have also have to add water as the air has been working its way out. Any ideas? Thanks!
Edit one thing to add, I know water pressure to the house is above 12-15 psi as I have a pump that pulls it up from the city gauge reads 55psi on that tank.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,345
    Brass plug
  • Intplm.
    Intplm. Member Posts: 2,811
    @mike3181 You still might have some debris in that line. Either that or your brand-new BFP is defective.
    Flush and clean that screen inside the thing and flush the water A LOT! I hope this will cure the issue.
  • mike3181
    Thanks! Is it normal to only be dripping when the boiler is firing though? Dry when boiler not firing.
    Can brass plug cause any problems?
  • Big Ed_4
    I am not sure if a vented BFP is code for the job …..
