pro press on baseboard
Is it always necessary to use a stiffer fitting when pressing copper baseboard tubing? I would be doing this on baseboard that has 180 degree water. Normally I would solder this, but this is a repair in a tight location. I saw where NIBCO makes a stiffner to go over the thin wall tubing I just have not used one before. Thanks to all
The stiffeners work, but sometimes they don't always go in the baseboard very easily. I've had to use a swage tool to expand the pipe to get the stiffener in. The sure fire way is just sweat a small section of copper in that you can press to
Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
2 -
I unknowingly pressed together a baseboard job many years ago and it has never presented any problems. Wasn't Slant/Fin though… some other brand.
the tubing in the baseboard i used to heat my workshop in the basement is about the same thickness as the aluminum fins
- 15.8K Strictly Steam
