pro press on baseboard
zepfan
zepfan Member Posts: 458
Is it always necessary to use a stiffer fitting when pressing copper baseboard tubing? I would be doing this on baseboard that has 180 degree water. Normally I would solder this, but this is a repair in a tight location. I saw where NIBCO makes a stiffner to go over the thin wall tubing I just have not used one before. Thanks to all
