A little TLC for the JB-5
delcrossv
Member Posts: 2,203
Pulled the panels on the MIL's 1960s era Weil Mclain and got a nice view of the firebox from the outside of the heat exchanger. A little furnace cement and all better. Did notice the case and boiler room were cooler.
Did no one notice the chunks of old cement lying on the floor?
Replaced one bad radiator vent,and I have a bad head on the MM 61 LWCO.(ouch!) Coming tomorrow.
Update. Replaced the LWCO head and the system shuts down on 12 oz pressure. Good for this winter.
Sooo, even with the weather getting colder, gas usage fell by 20% just due to the heat actually going through the heat exchanger, rather than around it. Repairing the cement looks to be the most cost effective fix to date.
MIL is happy.😍
- 50 Industry Classes
