Argo AR861-211 two zone issues.
I am new to this forum and new to heating issues. I have read most all of the postings on this unit but I would like a bit clearing up. To make sure I understand correctly. Have had no issues with this unit for over 15 years.
At start up this week. Neither thermostat turned on either pump to zone on or 2. I have checked all the relays. They seem fine. I have jumped a wire over both stat terminals and still nothing happens. Am I missing something else to test or do I need a new board?
Will attach photo asap.
Again. New to all this so may not understand all the lingo. Appreciate your time.
Do you have 110 volt power coming to the control?
Yes, 110 Power to the control.
A wire Jumping T1T1 should turn on zone one. Priority switch is on, so only zone 1 will activate while it has a call for heat.
Jumping T1T1 does nothing.
The transformer may have blown or the circuit board is history. Time to replace it.
Thanks Alan.. That is what I am thinking.. Just wanted to be sure.
- 50 Industry Classes
