Tiger loop installation
ksk
ksk Member Posts: 7
2 seperate tiger loop , 1 for each burner installed. Using original inlet on side of pump with return on bottom. Is this ok rather than the inlet/ outlets both on bottom of pump?
    HVACNUT Member Posts: 7,172
    That's fine, as long as the Bypass plug is in on both.
    I like to use a short 1/4" nipple and elbow out of the bottom, and make the connection on the horizontal so I can get a tray under the pump to catch the oil when I take off the pump cover.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,338
    edited September 2024
    You sill need a Fire-o-matic valve at the pump.. I would switch to the inline type using the bottom taps …
  • Grallert
    Grallert Member Posts: 1,014
    EBEBRATT-Ed Member Posts: 19,279
    Looks like they have firomatics at the pumps looks ok to me.
