Old viking boiler
Haveold viking coal powered now gas boiler
Idrain expansion tank every year
Noticedpressure was at 10psi usually at 16 when not being used
Idrained full systemfrom bottom of boiler drain
Question is
If water supply is on and the drain tap at boiler is open the drain should have flowing water out until water supply is shut off?
Ifno water is coming out of drain tap with water not shut off its the water being blocked at PRV?there is 2 in live one at 10 and 12
    EBEBRATT-Ed Member Posts: 20,074
    PRV could be plugged, or the drain valve could be plugged. Check the drain first. You can push a wire or a nylon cable ty through it. PRV may need replacing or strainer could be plugged.
