MAKE UP AIR HELP - FIELD CONTROL FAN-IN-CAN FOR GAS BOILER, WATER HEATER
FeelingColdColdCold
Member Posts: 15
in Gas Heating
Local plumber and electrician here in MA cannot solve so I can pass permit. Have 200KBurnham EN2 boiler, CAS4 Fan, and ADA-1 adapter. Adapter not working with damper clip on boiler PCB - need adapter or hardwire? Inspector also requires water heater tied in as well which means pressure switch? Inlet hole in wall, duct, all done. Need a competent HVAC person for this job in Newton. Hoping someone can help.
Good grief. This can't be that hard… do you have wiring diagrams for any of the equpment? Tying in the water heater may need a relay…
