Baxi issues
Hi Folks.
I have a customer w/ a Baxi 310Fi
older power vented combi that is in ok shape.
A leak has developed on the diaphragm switch. This is used to ramp up between heat and hot water... the pin that is activated w/ a micro switch is leaking around the nut and the sides.
I have looked at 2 different places and they have the part as no longer available. I even looked at a Fb marketplace unit but that had the same issue.
Any other options other than from italy/ via ebay?
Can this be pulled apart and repaired?
Anyone done that before?
part is 5629950
Thank you.
Thanks All.
Yes Blodgett in Concord was able to order it in for me. Thanks.
In this case it was a little more than just the diaphragm.
I replaced just that and it still leaked. Luckily I had the whole valve to make the fix.
On the whole its a neat little unit.
Kcopp,
I rarely say one boiler is better than the other, it's like having the conversation about who was the greatest sports person through the years, it's silly to compare. But I will say I have quite a few Baxi's out there and man they have been great. When they finally do have an issue though they can be a nightmare to fix. I say that to say, I get why you put a little money into that old girl, but it may be a good thing.
Tom
Montpelier Vt1 -
Tom.
I was the 3rd contractor through. the 2 previous said swap it out…go new.
I generally dont like doing that unless I really see something. I think there were much happier not having to shell out the cash.
Hi Again folks…
More Baxi questions… 310fi Combi
Same boiler. Apparently, each time the heat comes on there is a thumping noise. Sometimes hard sometimes soft.
Does not do it when making hot water.
thoughts?
ty. kevin
mechanical bang… There is an external extrol there in addition to the waterlogged pancake.
ty, kevin
Can you pipe a new tank in where the internal pancake is installed? even if you have to route piping out of the cabinet?
- 119 Chimneys & Flues
- 116 Geothermal
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
