Baxi issues
kcopp
kcopp Member Posts: 4,663
Hi Folks.
I have a customer w/ a Baxi 310Fi
older power vented combi that is in ok shape.
A leak has developed on the diaphragm switch. This is used to ramp up between heat and hot water... the pin that is activated w/ a micro switch is leaking around the nut and the sides.
I have looked at 2 different places and they have the part as no longer available. I even looked at a Fb marketplace unit but that had the same issue.
Any other options other than from italy/ via ebay?
Can this be pulled apart and repaired?
Anyone done that before?
part is 5629950
Thank you.
  • Tom_133
    Tom_133 Member Posts: 969
    Kcopp
    Sorry for the delay but Blodgett in Williston has them in stock and will UPS them to you
    Tom
    Montpelier Vt
    kcopp
  • If you have water coming out of the pin, then the diaphragm has a hole in it. Replace the diaphragm as the pin is on the dry side.
    kcopp
  • kcopp
    Thanks All.
    Yes Blodgett in Concord was able to order it in for me. Thanks.
    In this case it was a little more than just the diaphragm.
    I replaced just that and it still leaked. Luckily I had the whole valve to make the fix.
    On the whole its a neat little unit.
  • Tom_133
    Kcopp,
    I rarely say one boiler is better than the other, it's like having the conversation about who was the greatest sports person through the years, it's silly to compare. But I will say I have quite a few Baxi's out there and man they have been great. When they finally do have an issue though they can be a nightmare to fix. I say that to say, I get why you put a little money into that old girl, but it may be a good thing.
    Tom
    Montpelier Vt
    kcopp
  • kcopp
    Tom.
    I was the 3rd contractor through. the 2 previous said swap it out…go new.
    I generally dont like doing that unless I really see something. I think there were much happier not having to shell out the cash.
  • kcopp
    Hi Again folks…
    More Baxi questions… 310fi Combi
    Same boiler. Apparently, each time the heat comes on there is a thumping noise. Sometimes hard sometimes soft.
    Does not do it when making hot water.
    thoughts?
    ty. kevin
  • Tom_133
    Are you using an external expansion tank along with the pancake internally?
    Man, it's been so long since I have touched one of those. Is it a mechanical bang or a combustion bang?
    Tom
    Tom
    Montpelier Vt
    GGross
  • kcopp
    mechanical bang… There is an external extrol there in addition to the waterlogged pancake.
    ty, kevin
  • GGross
    GGross Member Posts: 1,843
    Can you pipe a new tank in where the internal pancake is installed? even if you have to route piping out of the cabinet?
