Sanity check for my radiant layout
Palusami
Palusami Member Posts: 1
Hi all,
I'm halfway through this radiant install and I wanted to make sure this layout is acceptable. I was a little worried about the T connection or 3 way mixing valve right before the pumps. Thank you.
  • EzzyT
    EzzyT Member Posts: 1,379
    If your system is going to operate on temperature there isn’t a need for a mixing valve.
    The layout looks good.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    hot_rod Member Posts: 27,452
    I’d rather not pull two pumps from a bull head tee, just stagger a tee and an ell
    One pump off the tee branch, one from the ell.
    With inverted manifolds you can get hermetically sealed actuators also.
    GGross
