Sanity check for my radiant layout
Palusami
Member Posts: 1
Hi all,
I'm halfway through this radiant install and I wanted to make sure this layout is acceptable. I was a little worried about the T connection or 3 way mixing valve right before the pumps. Thank you.
If your system is going to operate on temperature there isn’t a need for a mixing valve.
The layout looks good.0 -
- 125 Chimneys & Flues
