Gas boiler gun burner, pilot help
cunninghamzach
Member Posts: 19
Swapped a water heater, had to shut the gas off. Can’t get the pilot reignited on this burner, held the pilot dial down and a lighter to the orifice holes. What should I try?
Can't see the model number on the burner…………
Consulting0 -
Did you purge the air from the gas line before trying to light the pilot?
Note, do not purge into the combustion chamber.—
Bburd0
- 50 Industry Classes
