Gas boiler gun burner, pilot help
cunninghamzach
Member Posts: 19
Swapped a water heater, had to shut the gas off. Can’t get the pilot reignited on this burner, held the pilot dial down and a lighter to the orifice holes. What should I try?
Can't see the model number on the burner…………
Consulting0 -
Did you purge the air from the gas line before trying to light the pilot?
Note, do not purge into the combustion chamber.—
Bburd0
- 87.1K THE MAIN WALL
- 58 Biomass
- 115 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
