Pex B to tankless gas water heater
dough041
dough041 Member Posts: 34
I am installing a Rinnai gas tankless water heater.
My question is, should I run 18” of copper ( hot and cold ) from the unit then connect to pex? Not a good idea to run pex directly to the unit itself?
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    edited August 2024
    You want to come off the unit with hard pipe , secure the pipe to the building before Pex ..
    hot_rod Member Posts: 27,489
    A tankless valve kit is a good idea, as it will need occasional flushing
    Unless the installation manual tell you otherwise, I think you could pex to the valves
    GroundUp
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,106
    Hi, In some areas inspectors don't want any plastic pipe within a foot of the heater. I'd use stainless flex connectors from the heater and switch over to PEX from there. Or, find out how rules are enforced locally.
    Yours, Larry
    dough041
