Burnham steamer
Good day to everyone,l I’m not very active these days , just got old , lol!
So an old customer has a pin 4 Burnham steam boiler , asked me to take a look for him .
Looked ok , piping , well it’s worked 17 years !
First thing I gave it a general look over , looked ok . Then I decided to flood it , so as not to waste anymore time
The flood check was good , dropped it to water line and fired it up , so far all was good .
Then after starting to make steam , I heard a gurgling noise, then I noticed the top of the boiler was extremely hot . I had already by this time checked the draft and it was pulling good , as well had plenty of fresh make up air .
Looking around even more I saw the pressure gage , plastic cover was melted .
I’ll see if I can attach pictures, but I kinda recall someone had made up a wand type device to insert and do a real good flushing .
I would like to try that , as well add a skimming port, and skim it by the book !
I would definitely appreciate any suggestions any of you installers would have . Thank all of you in advance
    mattmia2 Member Posts: 15,477
    Looks like it isn't drafting right and is experiencing some amount of rollout.
    EBEBRATT-Ed Member Posts: 19,465
    I think there is a @gerrygill video floating around you tube that shows skimming and wanding.
  • Manofsteam
    Manofsteam Member Posts: 7
    Thank u both , yes at one time it was rolling out due to draft and crap between the sections , you are exactly correct!
    I kinda do remember a wand type tool made up , so yes thank u
    Steamhead Member Posts: 18,185
    Take the top panel off and see if the flue collector is sealed tight to the block. Escaping flue gases can do this.
    Consulting
    bburdmattmia2Mad Dog_2
  • Manofsteam
    thank u , Mr Steamhead , I will do exactly that.
    What do you think about the gurgling noise
    Not sure at this point- see what you find with the top off.
    Consulting
    Manofsteam
  • Manofsteam
    ok and thank u !
    I will do exactly that, and get back to you with my findings.
    Thank u again Mr Steamhead
