Extend flue Viessmann Vitodens 100-W
Looking for info on extending the flue on my Viessmann. Currently goes through wall to the outside, apx 2' horizontal run. Right where it comes out I am installing a 16' deep deck and I know it can be extended but not sure how. Searching for info and all I can see is to use CPVC pipe to extend it. Is it really that simple? The Viessmann website is not clear on this and I can't seem to find an extension kit from them. Can I just use a 16' length of 4" CPVC for this?
Alan, it is the concentric type flue. Appears to be the 60/100. For the life of me I can't find any supplier in the US that sells extension pipes. Is this something that has to be purchased direct from Viessmann?
Viessmann used to sell vent material and then Centrotherm Innoflue came along and we couldn't get Viessmann anymore and they are slightly different - not compatible.
The Innoflue catalog is here. I get my material from Cal Steam which is a Ferguson company.
@GGross will have more current information.
Cheaper and easier to go to a 2 pipe setup
Agreed. The 1-piece fitting looks sleek, but was hard to source when I was re-furnacing, and expensive, and I'm way back in the woods in a hard-lived shack so I don't need beautiful pipes.
That Viessmann furnace had a 2-pipe option. It looks like it needs a special plug which shipped with it but may be lost now. You need to boff another several-inch hole through the sill but modern battery tools make that play. The cost of two runs of pipe is probably much less than a run of coax pipe.
My only concern is pipes coming out at deck level. If cut flush to the edge the condensate fog/spray may rot the wood. If run long to clear the deckwork it may impale the guy on the lawnmower. My back wall, I ran the pipes up the 3+ feet to head-height (I needed 2+ feet anyway for snow clearance but that was face-high). This was days when cheap white PVC drainpipe was kosher for purpose. The smoke pipe used to be shorter but over two winters I noted that it frequently fogged the soffit vent and another foot of pipe was cheaper than wet insulation or rotting rafters. I once pulled a squirrel corpse out of a radon vent so I put screens on both pipes (the ex-suet feeder and the white ring).
