Extend flue Viessmann Vitodens 100-W
Looking for info on extending the flue on my Viessmann. Currently goes through wall to the outside, apx 2' horizontal run. Right where it comes out I am installing a 16' deep deck and I know it can be extended but not sure how. Searching for info and all I can see is to use CPVC pipe to extend it. Is it really that simple? The Viessmann website is not clear on this and I can't seem to find an extension kit from them. Can I just use a 16' length of 4" CPVC for this?
  • Is it currently a concentric vent (exhaust pipe within an air intake pipe) or single pipe?
    Use the same material and manufacturer of what is there now.
    460Cobradad
  • Alan, it is the concentric type flue. Appears to be the 60/100. For the life of me I can't find any supplier in the US that sells extension pipes. Is this something that has to be purchased direct from Viessmann?
  • Viessmann used to sell vent material and then Centrotherm Innoflue came along and we couldn't get Viessmann anymore and they are slightly different - not compatible.
    The Innoflue catalog is here. I get my material from Cal Steam which is a Ferguson company.
    @GGross will have more current information.
  • Cheaper and easier to go to a 2 pipe setup, PP for exhaust, PVC for intake
    PRR
  • PRR
    PRR
    edited August 2024
    Agreed. The 1-piece fitting looks sleek, but was hard to source when I was re-furnacing, and expensive, and I'm way back in the woods in a hard-lived shack so I don't need beautiful pipes.
    That Viessmann furnace had a 2-pipe option. It looks like it needs a special plug which shipped with it but may be lost now. You need to boff another several-inch hole through the sill but modern battery tools make that play. The cost of two runs of pipe is probably much less than a run of coax pipe.
    My only concern is pipes coming out at deck level. If cut flush to the edge the condensate fog/spray may rot the wood. If run long to clear the deckwork it may impale the guy on the lawnmower. My back wall, I ran the pipes up the 3+ feet to head-height (I needed 2+ feet anyway for snow clearance but that was face-high). This was days when cheap white PVC drainpipe was kosher for purpose. The smoke pipe used to be shorter but over two winters I noted that it frequently fogged the soffit vent and another foot of pipe was cheaper than wet insulation or rotting rafters. I once pulled a squirrel corpse out of a radon vent so I put screens on both pipes (the ex-suet feeder and the white ring).
