faucet drips
GTD
GTD Member Posts: 33
Hi tom here i have a american standard 2 handle shower tub valve i replaced 2 seats and stems they have aqua seal and it still leaks. what should check next. thanks
  • Did you use teflon tape or pipe dope on the threads when you replaced the seats?
  • GTD
    no
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,829
    edited August 2024
    I think you just answered @Alan (California Radiant) Forbes 's question. I've had water leak past the seats where they screw in. It can be a little frustrating. Seal those threads and see if the leak is gone.😎
    Yours, Larry
    Mad Dog_2mattmia2
    mattmia2 Member Posts: 12,694
    Also makes it possible to remove them in the future. I have also seen some seat wrenches that put a burr on the seat because they don't fit so well.
    hot_rod Member Posts: 25,054
    it is possible to cross thread seats when you reach in to replace them, that will cause a leak also
    I turn things like that counter clockwise until i feel the threads drop in, then i screw them in clockwise.
    Alan (California Radiant) ForbesDave Carpentier
