Converting a single zone 2-pipe hydronic heating system to multi-zone
I wish to multi-zone a single zone hydronic 2-pipe heating system that cast iron radiators with 1” angle valves.
I have been looking at a Shelly TRV.
Shelly claims that their TRV also controls the boiler (I presume circulation pump). I have used Shelly’s WiFi relay to close the connections on my hall thermostat, so I expect that is the intended method.
My home has several rooms each with at least one cast iron radiator. I wish set up each room as its own zone with a thermostat and appropriate radiator valves. This will place a variable flow demand on the circulation pump. I intend to address this issue using a smart circulation pump.
If this valve path is not achievable, I am considering using a thermal actuator, plus all the wireless relays and power supplies to make this happen. I would like to know if these actuators directly connect to TRV’s or will I have to make some adaptors.
Speaking about making adaptors, I have already built a system by modifying an off the shelf $18 radiator valve, making it a ¼ turn action and adapting a ¼ turn ball valve motor. I set it up to run a cyclic endurance test with a circulation pump and relays, to make sure the valve seals and other non-standard components survive but quickly came to the conclusion that the ball valve motors make too much noise for domestic applications. Also, by the time I make all the adaptions to my $18 radiator valve, it hardly competes with an off the shelf Thermostatic Radiator Valve.
Clearly, I am a novice at all this with enough background to make me dangerous. I would all the advice you can give me to steer me in the right direction and keep me out of trouble.
  • Ironman
    Ironman Member Posts: 7,898
    What type of boiler do you have? What’s its btu rating? How well is it matched to the heat loss of the house? Have you done a Manual J heat loss calculation or a radiation survey?
    Bob Boan
    hot_rod Member Posts: 27,249
    There are a few way to use TRVs with a delta P circ and operate the boiler
    A flow switch, an induction relay, or a pump that has a switching capability
    Then you could have room by room temperature control.
    Do a load calc, see how the boiler and radiators match the calculated load
    Too much zoning could cause short cycling issues
  • rfriedman
    rfriedman Member Posts: 8
    My Boiler is rated at 118 BTU/HR. I couldn't find a usable online J calculator, and probably do not have the background to do a qualified calculation. I will tell you that the boiler can bring the house from 62-68 on a cold winter day in about an hour.
    The boiler was sized by a qualified plumber and I assume it matches the load requirements with all the radiator valves open. I think the Delta P circulation pump will cover my flow rate, but I share the concern about short cycling the boiler. Am I correct in thinking the short cycling results is switch wear and more off peak performance usage?
  • Ironman
    How about posting some pics of the boiler and its near piping?
    How old is your house and how many square feet?
    Here’s a chart from which you can do a radiation survey. By determining the total square footage of your radiators (EDR), we can see how closely they’re matched to the size of your boiler.
    Bob Boan
