How to move an air valve on a Sunrad radiator?
JH3550
Member Posts: 33
I have three Sunrad radiators with the air valve located in the wrong spot. I have a one pipe steam system, and the valves are in the upper corners. On one radiator it’s even on the wrong side (same side as the supply).
In the correct location for the valve there is a raised circle. Is this a plug that can be removed or is it just a guide for drilling and tapping a hole?
Thanks!
yeah, but, wait,
is that the right end, or the left end, from the first picture?
the 1st picture looks like the supply comes in the right side,
you would want the vent on the left side, 1/2 way down,
known to beat dead horses0 -
good catch. It’s actually a different radiator than the first picture. Supply is in the opposite side.
@JH3550 , how about some "after" pics?
Consulting0 -
- 15.8K Strictly Steam
