How to move an air valve on a Sunrad radiator?
JH3550
JH3550 Member Posts: 33
I have three Sunrad radiators with the air valve located in the wrong spot. I have a one pipe steam system, and the valves are in the upper corners. On one radiator it’s even on the wrong side (same side as the supply).
In the correct location for the valve there is a raised circle. Is this a plug that can be removed or is it just a guide for drilling and tapping a hole?
Thanks!
    EBEBRATT-Ed Member Posts: 20,482
    Yes, the correct location is halfway up on the opposite of the supply end.
    If that is a removeable plug it would have an inside hex for an Allen wrench. If not, it could be drilled and tapped.
    JH3550
  • JH3550
    UPDATE: what appears to possibly be a plug IS a plug. I used a number 5 hex wrench. Scraped the paint, sprayed some penetrating oil, used some elbow grease, and voila!
    PC7060Intplm.
  • neilc
    neilc Member Posts: 3,196
    yeah, but, wait,
    is that the right end, or the left end, from the first picture?
    the 1st picture looks like the supply comes in the right side,
    you would want the vent on the left side, 1/2 way down,
    known to beat dead horses
  • JH3550
    good catch. It’s actually a different radiator than the first picture. Supply is in the opposite side.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    You lucked out….
    JH3550
    Steamhead Member Posts: 18,710
    @JH3550 , how about some "after" pics?
    Consulting
  • JH3550
    edited July 2024
    Before:
    After:
    (The before picture is old. I had to swap out the air valve bc it was old and failing this past winter.)
    bburdCLamb
