How to fix small radiator access "end caps?"
Hi -
I have a hot water radiator system in my home. In my laundry room I have a very small radiator - 4'1" long, 9" tall and about 5" off the floor. This looks to be original to the house - about 1940. I've posted some pictures below. Both "end caps" of this radiator are rusted and beat up and are easily removed to show the bleed valve, etc. These end caps once had a metal access door on the front, but those are long gone, and someone screwed a rubber flap onto the front where those access doors once were (black part of the 2nd photo). Questions - 1) Are these access doors still made and, if so, where could I get two? and 2) If they aren't made, any suggestions as to how to repair these and what, maybe, to use instead of rubber flaps? Many thanks!
Not sure what brand that is, but if it's out of production you may have to have a replacement custom-made.
Consulting0 -
About 40 bucks each. Left is 18 cents more than right????
Go down, SupplyHouse has corners and fillers and other goodies.
https://www.supplyhouse.com/Burnham-Baseray-Accessories-17690000
Back in the day, the counter guy would risk providing the wrong part, angering the customer (and there were a lot fewer parts in the world). Part numbers help to remove that liability.
