Overnight gas shutoff and nightlight for stairs 1893 (also Freon 12 in 1943)
Freon 12 definitely has an odor. Shutting off the town gas was probably to avoid everyone dying of co poisoning in their sleep.
It's also extremely toxic when burned but we never let facts get in the way of good advertising.
The refrigerant itself has no order, when in a system you're smelling the oil.
It isn't in a system when it was in an air duster(freon 12) can or an electrowash(freon 113) can and it has the same odor.
The same thing could be said of wood or plastic and those are a lot easier to construct conditions where they burn.
R-12 has no odor. Whatever you smell is something else carried by the R-12. It may or may not be flammable I don't know but phosgene gas it a major problem.
It has an odor according to wikipedia:
It is not flammable but will decompose if heated sufficiently.
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
