Temp Control on HTP model PHE130-119S
pnunes531
Member Posts: 2
If someone could kindly point me to a manual or provide instructions on how to control the temperature on above model I would appreciate it. I would like to turn down the water temperature. Thank you in advance.
https://www.htproducts.com/literature/lp-179_0417.pdf
This might be your manual, but it depends on the date of manufacturer.
By the looks of things there is a display screen on the appliance. you must go into the setup menu to get to the temperature adjustments.
