Temp Control on HTP model PHE130-119S
If someone could kindly point me to a manual or provide instructions on how to control the temperature on above model I would appreciate it. I would like to turn down the water temperature. Thank you in advance.
    EdTheHeaterMan Member Posts: 12,168
    https://www.htproducts.com/literature/lp-179_0417.pdf
    This might be your manual, but it depends on the date of manufacturer.
    By the looks of things there is a display screen on the appliance. you must go into the setup menu to get to the temperature adjustments.
    PC7060
  • pnunes531
    pnunes531 Member Posts: 2
    Thanks for suggestion, it wasn't the exact manual for this 2018 model which had a different control panel but I was able to locate it, and if anyone needs the control panel for this model year you can find the manual at:
    https://www.htproducts.com/literature/lp-314_0417.pdf
