Plumbing math
Youuse
Youuse Member Posts: 2
been having trouble tryna figure out the missing values what you guys think
ratio
    EdTheHeaterMan Member Posts: 12,206
    edited May 2024
    Why would you even want to build it? It has no purpose… Water wise, you need a goesinta, and a goesauta for it to have any real use.
    Is that the left side of a recliner made of copper?
    Intplm.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,713
    Is this on a test you’re taking in school?
    Retired and loving it.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,550
    If those are 45 degree offsets, it's
    1. 1.41 X the offset (center to center)
    2. Deduct for the distance from end of tubing to center of fitting.
    3. The offset & advance are the same
    Example:
    If you have a 12" Offset, the travel piece will be 17"s.
    As Dan asked, is this for class, a project or License?
    Mad Dog
    EBEBRATT-Ed Member Posts: 20,194
    you need to know the pipe size
    Mad Dog_2
  • Mad Dog_2
    Yes!! You do need to know the pipe size for your takeoffs...Mad Dog
  • GW
    GW Member Posts: 5,184
    edited May 2024
    That's a semi-odd illustration/math problem, took me a moment to understand the 'handwritten' numbers are given numbers. And, what bizarre angles, one pic seems to be 45s and another seems to be 22 1/2 or 11 1/4.
    Size of the pipe doesn't matter, these are center-to-center measurements, not the actual length of the pipe (in a real world scenario)
    Are we to assume 45 degrees? Then the .707 and the 1.414 kicks in.
    I give up, they don't give any clues. Are you supposed to assume G and M are 1/3's of D?
    If we assume that, how does one assume the other letters? E,F and L,K?
    Time to send this quiz writer back to school, is my answer
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • CLamb
    CLamb Member Posts: 348
    Are all the connections either 90º or 45º? Are we supposed to determine which is which visually?
