Resideo HPSR10 switching relay panel
What is the purpose of the boiler terminals ? Do they send 24vac to the boiler plug-in relay to activate the boiler or are they a continuity contact? Thanks
Boiler terminals are dry contacts and are just a switch to turn the boiler on. anytime one of the zones call for heat the switch closes sending voltage back to the boiler circuit.
Thanks pedmec. That will help alot.
To be just a little more clear
Boiler terminals are dry contacts and are just a switch to turn the boiler on. anytime one of the zones call for heat the switch closes allowing voltage to go back to the boiler circuit.
But I think you got the point
Yes, thanks for the help. I have been looking on line for information on this. Should have looked for the experts here first.
Hello egnuol,
Installation Instruction manuals here if you need more information.
https://www.resideo.com/us/en/pro/products/water/hydronic-solutions/controls/four-zone-switching-relay-120-vac-1ph-hpsr104-u/#resources
https://digitalassets.resideo.com/damroot/Original/10014/33-00349EF.pdf
https://digitalassets.resideo.com/damroot/Original/10014/33-00331EF.pdfNational - U.S. Gas Boiler 45+ Years Old
One Pipe System0 -
Thanks 109. I wasn't sure about the boiler and end switch purposes.
- 50 Industry Classes
