Resideo HPSR10 switching relay panel
What is the purpose of the boiler terminals ? Do they send 24vac to the boiler plug-in relay to activate the boiler or are they a continuity contact? Thanks
  • pedmec
    pedmec Member Posts: 1,460
    Boiler terminals are dry contacts and are just a switch to turn the boiler on. anytime one of the zones call for heat the switch closes sending voltage back to the boiler circuit.
  • egnuol
    egnuol Member Posts: 13
    Thanks pedmec. That will help alot.
    EdTheHeaterMan Member Posts: 12,504
    To be just a little more clear
    Boiler terminals are dry contacts and are just a switch to turn the boiler on. anytime one of the zones call for heat the switch closes allowing voltage to go back to the boiler circuit.
    But I think you got the point
  • egnuol
    Yes, thanks for the help. I have been looking on line for information on this. Should have looked for the experts here first.
    109A_5 Member Posts: 4,207
    Hello egnuol,
    Installation Instruction manuals here if you need more information.
    https://www.resideo.com/us/en/pro/products/water/hydronic-solutions/controls/four-zone-switching-relay-120-vac-1ph-hpsr104-u/#resources
    https://digitalassets.resideo.com/damroot/Original/10014/33-00349EF.pdf
    https://digitalassets.resideo.com/damroot/Original/10014/33-00331EF.pdf
  • egnuol
    Thanks 109. I wasn't sure about the boiler and end switch purposes.
