Forced air on first floor, mini splits on 2nd floor?
Kman18
Kman18 Member Posts: 14
A house I'm considering buying (cape style, 2,000 sq ft) has forced air on the first floor, and mini splits in each room on the 2nd floor. Seems strange to have both systems in one house, and I'm concerned with the upkeep & expense of 2 systems instead of one. Is this an unusual set up? Will it be more expensive to run 2 systems?
  • KC_Jones
    KC_Jones Member Posts: 5,932
    2014 Weil Mclain EG-40
  • GGross
    GGross Member Posts: 1,869
    It's not entirely unusual. All systems require upkeep , the biggest expense in having 2 systems is the cost of installing 2 systems. If that part was already done I wouldn't worry about the upkeep too much. The cost to run will be roughly the same as a single system, but now you don't rely on a single piece of equipment to heat the whole house, so if something breaks you still have a partially heated house
