What is this on a 100+ year old system?
Dave2012
Dave2012 Member Posts: 2
Came across this and wondering what this is and what was it's purpose?
    Jamie Hall Member Posts: 26,679
    Honeywell Heat Generator, and it functions — very nicely with no moving parts — to maintain the correct water pressure in the system.
    Don't mess with it! It contains mercury — in fact a pretty fair amount of it — and that is the last thing you want spilled all over the place. But it is completely safe as is.
    bburd
    Steamhead Member Posts: 18,147
    @Dave2012 , I think @Jamie Hall is right, but I also see what looks like a McDonnell & Miller #67 low-water cutoff in the background, that would be used on a steam boiler. Can we see some more pics of this boiler, from the front and the other side?
    Consulting
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,361
    Mercury repository...Ne mindful Mad Dog
    EBEBRATT-Ed Member Posts: 19,172
    probably just used the #67 on a hot water boiler. Also, an aquastat in the picture as well as a stack switch.
    If they did it's not the best choice. It's only rated 20 PSI max, and the safety on the usual hot-water boiler is 30 PSI.
    Consulting
  • Erin Holohan Haskell
    Erin Holohan Haskell Member, Moderator, Administrator Posts: 2,361
    Here's the original circa-1910 literature for the Honeywell Heat Generator.
    And here's a cautionary tale about it.
    President
    HeatingHelp.com
    PC7060
  • sopcopotoptop
    sopcopotoptop Member Posts: 26
    It looks incomplete. The tube within a tube appears to be missing as well as the mercury containing lower portion. Modified at some point?
    mattmia2 Member Posts: 15,067
    edited July 2024
    I think the top of it is just cut off in that picture. The dish part is the bowl of mercury that is the pressure regulator.
    Or maybe that is just the top dome. I thought i've seen versions that were just that dish before but some googling reveals the pictures I thought i saw had a bottom piece. Looks like they just left the dome in place when the converted to a closed system or an automatic burner.
    sopcopotoptop
