This is a fitting
Is it a rogue, counter culture, problem, uncouth fitting? Nope, it's just a fitting.
It's made for one thing and some may recognize it. It fits into a water heater heating element hole and converts it to FIP. Not an easy find. Is it a discouraged fitting? Maybe it is. It allows for connections that some desk sitters don't want made. If you didn't know, now you know. What you can do with it is up to you. You can figure out the sizes. I've not had one fail or leak. The first run in is tight. Anti seize or just T paste. SS is what I have but brass would work.
One of my hero's is Robert De Niro's character in the 80's movie "Brazil" The great Harry Tuttle. This post is in his honor. Central Service guys, don't waste your time. In keeping with Tuttle's style, comments will not be responded to. News papers swirl up into the air and he's gone.
A little trick I've picked up: the pitch of BSP is the same as NPT, but the thread shape is different so they won't go together. However, if you run a BSP male fitting through an NPT tapping die you can shave enough to get them to go together, especially if the fitting is a soft metal like brass that will deform a bit.
BSP seals with a rubber washer, as shown. Depending on the situation you may need to keep the washer.
BSP threads have the same pitch as NPT only in 1/2".
I would not recommend attempting to utilize a 1/2" NPT male adapter which will easily thread into a BSP 1/2" FIP fitting. The o-ring cannot effectively be utilized and it will eventually leak. Learned this the hard way. Get the proper transition fitting.
I think that California covers that under the Lemon Law, so you are stick with that color
1/2 and 3/4 are both 14 TPI in both BSP and NPT. BSP is slightly larger than NPT, NPT male into BSP female is going to leak. What I'm saying is that if you have BSP male you can rethread it into NPT male. I wouldn't do this on a fixture because it's kind of risky but if you have a BSP to BSP fitting and can't get the adapter to NPT you need, this is a way.
And I just thought it was a lemon?
This site says different:
I happen to have a 3/4" BSP-G female fitting sitting on my desk next to the computer. A 3/4" NPT male fitting screws into it easily.
The BSP fitting is on the left, if you look you can see the threads are shaped differently from the NPT fitting on the right, they're flat across the tops and the NPT ones are sharp.
I can't figure out how to get that picture not to be squeezed but if you click on it you can see the original version.
please delete
fixed. please delete.
We're troubleshooting this. Thanks for your patience!
President
HeatingHelp.com0 -
Has anyone mentioned where to get them?
Tom
Montpelier Vt0 -
For simple same-size straight BSP to NPT the best place I've found is Amazon:
or
More complicated size-changing or elbows you can sometimes find on Ebay. Often the fittings don't come with rubber washers but I find US-size ones work fine.
Hydronics is more popular in Europe than in the US, so there is a much better selection of radiators and fan coil units from European manufacturers. But they all have BSP fittings.
I got into re-threading BSP when I had a radiator with 3/4" BSP that I needed to connect to 1/2" PEX while making a 90-degree turn, all in a couple of inches. I couldn't figure out how to make those transitions without at least three fittings, which wasn't going to fit. I got a 3/4" BSP to 1/2" BSP male adapter, rethreaded the 1/2" side to NPT and screwed that into a 1/2" NPT/PEX elbow.
I must admit from looking at the pictures and reading into this post I have actually had this type of fitting in my hands and installed it probably numerous times and didn't know what it was. I just thought it was another adapter or fitting. And no leaks so far.
@Teemok a very informative post.
