Stainless Steel Indirects with electric are hard to find...
Wellness
Member Posts: 154
Looking for an 80 gallon stainless steel indirect tank with electric backup. Heat-flo has apparently discontinued their electric backup models and two distributors I contacted in my market claim that ECR International, Inc. (which handles Utica Boiler products) doesn't ship its electric backup model H2OI80DEUB to the Virginia market. Anybody know any other makers of 80 gallon stainless steel indirect tank with electric backup?
To be used as a standard indirect to a boiler? Single coil? Dual coil? Solar application?
https://www.htproducts.com/superstor-ultramax-multisource.html
https://www.lochinvar.com/products/indirect-tanks/squire-indirect-waterheater (SDT/SET models)
https://www.chiltrix.com/heat-exchanger-tanks/
Yes. As standard indirect. I don't need the boiler running in the hot spring and summer. But of the links you posted, only the HTP & Lochinvar appear to have electric backup. Thanks for that, though. It helps.0
I used one of these for a solar DHW system, see if they could suit your needs:
https://www.dudadiesel.com/search.php?query=+soltank&i=info_SolarNJ Steam Homeowner.
Search for solar tanks. They tend to have electric backup.
Personally I prefer a glass lined tank to the stainless, especially if you have high chloride levels.Bob "hot rod" Rohr
Living the hydronic dream2
- 116 Geothermal
- 15.8K Strictly Steam
