hard set thread dope/ disassembly
rtv
Member Posts: 74
I've run into some pipes that someone used some kind of white very hard pipe dope.
will it let loose with heat or is together for ever? Thanks!
Hard set should never be used on cast iron ...
Hi, Can you chip some of it off and see what happens to the chips when heated? Maybe put the chips on a piece of sheet metal and heat from underneath?? If the chips soften, there is a likelihood that heating will let you unscrew the joint.
Yours, Larry0 -
Nothing is together forever unless it's welded. Don't expect to reuse the fittings..but you CAN get anything apart. Mad Dog1
yeah...there are a lot of things they did that you should never do! i'm just trying to fix them one by one0 -
larry,
i'll give it a try! thanks0 -
How old is this connection? Lead based paint was used as a pipe dope in some cases.Bob "hot rod" Rohr
Not very old at all...15yrs-20?0
You couldn't get it apart , educated guess cast iron was involved and hard set dope ..
Only that's greyish black, so it wasn't that.
First, try to tighten that fitting just to move it. Sometimes, since all the torque on the fitting was in the tightening direction, you may be able to get it to move ever so slightly, enough to break the hold of the dope. If this works, you have accomplished your task. Also, you can try tapping the fitting with a 4# hammer with a backup. If this doesn't work, get bigger wrenches.1
Great advice retireguy. People think you are nuts tightening a joint you can't get apart. It works. If the fittings are cast iron, don't go crazy with the hammer. Cast fittings will break if you swat them too hard.
@retiredguy sez,If this doesn't work, get bigger wrenches."Give me a lever and a place to stand and I can move the world."0
