hard set thread dope/ disassembly
rtv
rtv Member Posts: 74
I've run into some pipes that someone used some kind of white very hard pipe dope.
will it let loose with heat or is together for ever? Thanks!
  • Big Ed_4
    Big Ed_4 Member Posts: 3,530
    Hard set should never be used on cast iron ...
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,117
    Hi, Can you chip some of it off and see what happens to the chips when heated? Maybe put the chips on a piece of sheet metal and heat from underneath?? If the chips soften, there is a likelihood that heating will let you unscrew the joint.
    Yours, Larry
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,564
    Nothing is together forever unless it's welded. Don't expect to reuse the fittings..but you CAN get anything apart. Mad Dog
    Intplm.
  • rtv
    yeah...there are a lot of things they did that you should never do! i'm just trying to fix them one by one
  • rtv
    larry,
    i'll give it a try! thanks
    hot_rod Member Posts: 27,504
    How old is this connection? Lead based paint was used as a pipe dope in some cases.
  • rtv
    Not very old at all...15yrs-20?
  • Big Ed_4
    You couldn't get it apart , educated guess cast iron was involved and hard set dope ..
  • ChrisJ
    ChrisJ Member Posts: 17,412
  • ChrisJ
    Only that's greyish black, so it wasn't that.
  • retiredguy
    retiredguy Member Posts: 1,094
    edited April 2024
    First, try to tighten that fitting just to move it. Sometimes, since all the torque on the fitting was in the tightening direction, you may be able to get it to move ever so slightly, enough to break the hold of the dope. If this works, you have accomplished your task. Also, you can try tapping the fitting with a 4# hammer with a backup. If this doesn't work, get bigger wrenches.
    Mad Dog_2
  • Mustangman
    Mustangman Member Posts: 115
    Great advice retireguy. People think you are nuts tightening a joint you can't get apart. It works. If the fittings are cast iron, don't go crazy with the hammer. Cast fittings will break if you swat them too hard.
  • HomerJSmith
    HomerJSmith Member Posts: 2,780
    @retiredguy sez,
    "Give me a lever and a place to stand and I can move the world."
