US boiler recall notice
gyrfalcon
Member Posts: 188
Slant Fin Galaxy GG100(1986) , 2 zone hot water baseboard, T87 Honeywell thermostats.
gyrfalcon said:
Hazard:
The blocked vent switch (BVS) can fail to shut down the burners if the boilers are installed at altitudes above 5,400 feet and the vent system becomes blocked. In such an event, the boiler can emit excessive amounts of carbon monoxide into the home, posing a carbon monoxide (CO) poisoning hazard to consumers.
U.S. Boiler ES2 models ES23, ES24, ES25, ES26, ES27, ES28, ES29 (with or without “-N” or “-P” suffix)
I have an ES27 - but it's installed in Chicagoland so I assume this recall does not apply to my situation.
Eric0 -
Crown AWR boiler By Velocity Boiler Works has the same issue. https://www.cpsc.gov/Recalls/2024/Crown-Boiler-Recalls-Home-Heating-Boilers-Due-to-Carbon-Monoxide-Poisoning-Hazard
It is a simple fix.Edward Young Retired
Did you get the fix from Crown?
Since I'm not a contractor, I don't think US Boiler will work with me.
Eric0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
