floor drain metal access panel replacement?? where to find
no latches or hinges found some steel plates on amazon they look like they will fit0
Here is where I get metal. Luckily I have a location about 2o miles from me.
you could get a piece of aluminum and not worry about rustingBob "hot rod" Rohr
When you find out what they cost you might decided you are ok with just cleaning them up and painting them. I'd go cold galvanizing compound then paint or something like KBS Coatings or por-15.0
Theres a floating floor, vinyl plank flooring installed above it and a hole developed partially because the support below was inadequate.
I found a nice 12x12 1/4" thick steel plate on Amazon that fit perfect. The extra thickness helped with the flooring issue (not level its a basement).. We placed the new plate over the old access plate. Im surprised Home Depot/Lowes doesnt carry these plates and outdoor grates, even my local plumbing supply house was out of stock
it is more a whoever your local metal wholesaler is thing than retail or plumbing0
- 120 Geothermal
