Hot water boiler re-pipe and pipe sizing question
Bcos17
Member Posts: 46
in Gas Heating
I’m in the middle of planning a re-pipe of my poorly installed Williamson hot water boiler. My question is about pipe sizing, specifically when to reduce the pipe size out of the boiler (1-1/4”) to 1” feeding a Cross Manifold I plan to use. Should I reduce it with a bushing right out of the boiler so the first cast iron nipple I use is 1”? Or should I wait until right before the cross manifold to reduce the copper from 1-1/4” to 1”? The boiler is 66k BTUs and it is feeding around 50-60 feet of baseboard in 3 zones.
Does anyone see any problems with my setup as I’ve outlined it here?
Is that an indirect water heater after the manifold?
Would it be helpful to keep the laminar type flow of the water going into the air separator or does it work better if the water stream is "bashed" up by being restricted from 1 1/4 to 1 just before it?
Would not the gut feeling if not science indicate you should carry on the 1 1/4 pipe for at least say 3-6 ft after the tapping port? Why not all the way to the manifold?0 -
Air floats...
No indirect water heater involved. I think you might be looking at the picture of the Adey Magnaclean XP2 dirt separator?john123 said:Is that an indirect water heater after the manifold?
