Bradford White Model MI5036FBN Hot Water Heater not heating
dksagun
Member Posts: 8
Pilot light is on. Burner never ignites. Troubleshooting chart indicates Temperature Sensor Fault based on LED status. Based on this error condition, troubleshooting manual says temperature sensor or gas valve may be the problem. Is there anything else that could be causing this issue> Please advise on other troubleshooting steps I could perform to resolve this issue.
It is possible that the water temperature was too high at some point in the operation of the water heater. If that happens then the programming of the control will lock out the gas valve and cause a 4 flash then a 3 second pause then 4 flash repeating error code. That code requires turning off the heater for 5 minutes, then following the lighting procedure to get the water heater operating again. Is that what is happening in your situation; a 4 flash error code?
If that is the case the first thing I would try is to lower the thermostat dial on the water heater by 5° F to see if the problem stops. If not, then lower the dial 5° more, still have the problem… Then replace the temperature sensor probe. I believe it just plugs into the control.
Here is the service manual for the water heater https://s3.amazonaws.com/s3.supplyhouse.com/manuals/1269613234184/28334_PROD_FILE.pdf If that helps.
Hi, This may seem a silly thing to say, but I've seen it multiple times. Is the control knob in the correct position? I've had to make trips just to move the knob from pilot to on.
Yours, Larry0
