counterflow main venting
ahearnj
ahearnj Member Posts: 3
Are main vents required in a steam counterflow system? One contractor has said yes another no? if yes, where should they be located? Thxs
  • KC_Jones
    KC_Jones Member Posts: 5,890
    Yes they are needed and they should be at or towards the end of the main, similar to a counterflow.
    Counterflow or parallel flow, the steam still needs to move through the main in the same manner so the venting concepts are identical.
    2014 Weil Mclain EG-40
    delcrossvethicalpaulSTEAM DOCTOR
  • Big Ed_4
    Big Ed_4 Member Posts: 3,334
    What do you mean counter flow system ?
    EBEBRATT-Ed Member Posts: 19,172
    @Big Ed_4
    The mains are lower at the boiler and high at the far end. Stem goes up the top of the pipe and condensate come s back the bottom
  • Big Ed_4
    Thanks
