Soot on aquastat
duh
duh Member Posts: 21
What could cause soot to appear on the inside of the closed cover of an aquastat mounted on top of a Buderus oil-fired boiler, model GS115WS4?
    EdTheHeaterMan Member Posts: 12,190
    Convection currents would bring airborne carbon particles from incomplete combustion into the tiny openings of the control.
    OR
    There could be an electrical restriction causing resistance in a wire. the insulation on the wire would overheat and start to burn and leave soot marks.
    Look at the location of the soot and the wires around it.
    HVACNUT Member Posts: 7,450
    Clean it and see if it returns.
    The aquastat sits on top, near the rear of the boiler. Where is the draft regulator in relation?
