New low pressure gauge reading zero
It certainly did on mine.EBEBRATT-Ed said:The weight of the water in the pigtail has no effect on the gauge reading if the gauge is above the boiler tapping
So much I stopped using one on the actual gauge I use. In fact if it kept skewing a 3 psi gauge I imagine it would destroy a 2" magnehelic.
Or at least make it totally useless.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Lol 😅 .. you're the first person I thought of when I read this post... It's like you have RADAR when this comes up, 😉ChrisJ said:
Or at least make it totally useless.One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0 -
The less pressure you need to heat a steam system the better it proves all vents/traps are workin ignore pressure do all radiators get hot? Job done0
Pressure does not get steam there to end of line relieving air does0
