New low pressure gauge reading zero
2»
  • ChrisJ
    ChrisJ Member Posts: 16,585
    The weight of the water in the pigtail has no effect on the gauge reading if the gauge is above the boiler tapping
    It certainly did on mine.
    So much I stopped using one on the actual gauge I use.  In fact if it kept skewing a 3 psi gauge I imagine it would destroy a 2" magnehelic.
    Or at least make it totally useless.
  • reggi
    reggi Member Posts: 526
    edited March 2024
    Lol 😅 .. you're the first person I thought of when I read this post... It's like you have RADAR when this comes up, 😉
    One way to get familiar something you know nothing about is to ask a really smart person a really stupid question
  • ChrisJ
    It's not my fault
       :D
    reggi
  • Panheadsforever
    Panheadsforever Member Posts: 21
    The less pressure you need to heat a steam system the better it proves all vents/traps are workin ignore pressure do all radiators get hot? Job done
  • Panheadsforever
    Pressure does not get steam there to end of line relieving air does
