Bosch Greenstar ZBR28-3 or Navien NHB110H
Chevy57
Member Posts: 8
Folks,
Which one do you choose? 4 zones controlled with pumps. First and second floor use cast iron radiators but 1 1/4 Pex aluminum Pex instead of 2" cast iron pipes to feed them. third zone is radian floor in the kitchen and the final zone is side arm water tank. Which one and why?
Neither.Bob Boan
Bosch between the two...
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.1 -
which guy can best service the boiler down the road? That's the general answer.
For a Cast iron rad job I'd be digging the Viessmann CU3A0 -
Why not Navien? We have installed dozens of various Navien models over the last 6 or so years and they work. Basically problem free. I hear that they have good tech support but I hardly know because I don't have need to call them. Sure that may change some as the units age.0
Navien , suck if you need to replace parts .... That's their problem in engineering ..
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
